Blow-by
Blow-by
Postby mhuppertz » Tue Nov 13, 2007 3:05 pm
I pulled the oil filler tube cap today and I was getting significant choo choo stack happening. I replaced the cap and it didn't look like anything was coming out of the stinky slinky. How do I clean that dude out? I can't even see where it's connected to the engine.... Maybe that's why my rear main is leaking so badly!
mhuppertz
Postby ford69557ci » Tue Nov 13, 2007 5:56 pm
if your cc vent is clogged it will cause some major oil leaks i have mine vented on the valve covers and the factory tube seems like it doesnt use as much oil setup like that
ford69557ci
Postby mhuppertz » Tue Nov 13, 2007 6:33 pm
ford69557ci wrote:if your cc vent is clogged it will cause some major oil leaks i have mine vented on the valve covers and the factory tube seems like it doesnt use as much oil setup like that
Did you put a vent on all the covers, or just one?
mhuppertz
Postby cummins king » Tue Nov 13, 2007 6:37 pm
u only need one, anything else is for looks
93 4X4 auto
cummins king
Postby mhuppertz » Tue Nov 13, 2007 9:31 pm
cummins king wrote:u only need one, anything else is for looks
What kind do I use? I don't want oil puking all over the engine.
mhuppertz
Postby ford69557ci » Tue Nov 13, 2007 9:42 pm
i have 3 and yes one on top is all you need but i like shinny things. i have open element k&n breather filter off of one of my old drag truck projects they are open element and i get no oil on top of my engine
ford69557ci
Postby mhuppertz » Sat Nov 17, 2007 9:11 am
Here is what I did, a K&N happened to fit perfectly over the filler...
http://www.dieseltruckresource.com/pics ... small_.jpg
mhuppertz
Postby flashgordon » Sat Nov 17, 2007 10:16 am
mhuppertz wrote:Here is what I did, a K&N happened to fit perfectly over the filler...
Grate pic, had me a little confused there, until i seen the pic nice and clean setup. :thumleft:
NOTE......Clicking on the link didn't work for me.......but copy and paste in the browser did. ;)
Flash.
flashgordon
Postby mhuppertz » Sat Nov 17, 2007 5:30 pm
mhuppertz
Postby cummins king » Sat Nov 17, 2007 5:36 pm
hey you got an electric fan on yours did you notice any powr difrence
93 4X4 auto
cummins king
Postby cummins king » Sat Nov 17, 2007 5:38 pm
hey mr ford any pics of your engine
and mr. mhuppertz whats the moddle of youR filter
93 4X4 auto
cummins king
Postby mhuppertz » Sat Nov 17, 2007 7:50 pm
cummins king wrote:hey you got an electric fan on yours did you notice any powr difrence
It didn't give me more power, but it made the power I have more consistent, as in the same weather the air is on, start and stop traffic, etc.
My mileage went up a solid 2 MPG, averaged over 20 tanks.
mhuppertz
Postby mhuppertz » Sat Nov 17, 2007 7:54 pm
cummins king wrote:mr. mhuppertz whats the moddle of youR filter
It's Mark, and I have a Luber-Finer Diesel Pack Model 200. It's a '60s model, and the filters are gettting hard to get, and they are $60 bucks a piece. But I highly recommend a bypass filter.
mhuppertz
