Lift Question
Lift Question
Postby ramtough1993 » Thu Apr 12, 2012 9:57 am
I was looking at putting a little lift on my truck to make it look proportionate with the roll bar and all. My plan was to by a kit with 2 inch blocks for the back and and add a leaf that will give me 2 inches in the front. Will this affect my steering components and drive shafts? or will I be safe as far as that goes?
1993 Dodge Power Ram 150 4x4, 5.2L Magnum, Automatic Transmission, Work Special Package, Currently mostly stock
ramtough1993
Re: Lift Question
Postby BILTIT » Thu Apr 12, 2012 10:10 am
It will most likely effect your steering. The draglinks on these trucks are not adjustable so you would most likely have to buy an adjustable draglink.
Derek B.
BILTIT
Re: Lift Question
Postby RumbleFish » Thu Apr 12, 2012 11:18 am
Your truck has about a 3" block in it from the factory. Stacking blocks is dangerous and a terrible idea. You could put a 5-6" block in it, or go with drop shackles from jungle, an add a leaf, or a rear lift spring.
Re: Lift Question
Postby BILTIT » Thu Apr 12, 2012 11:33 am
Here is a link to what Jungle offers.
http://ramchargercentral.com/jungleshddodgecomponents/
Derek B.
BILTIT
Re: Lift Question
Postby ramtough1993 » Fri Apr 13, 2012 5:35 pm
Okay that doesn't sound so bad i just wanted to make sure that I wouldn't have to get all new driveshafts and other components because that could get costly but an adjustable drag link doesn't sound that bad.
ramtough1993
Re: Lift Question
Postby ramtough1993 » Fri Apr 13, 2012 5:37 pm
Now the 5-6 inch blocks do they make such a thing or would that be something to go to a local fab shop for?
ramtough1993
Re: Lift Question
Postby BILTIT » Fri Apr 13, 2012 7:53 pm
5-6'' blocks were stock in the 92-93 years i believe. They are available in the aftermarket aswell.
Derek B.
BILTIT
