ahale2772 wrote:so the biggest thing im confused about is.... what rotors should I buy for this application? Napa says there is two options, either a rotor that is 1.5 inch thich (same thickness as the 1ton rotors on there now) or a 2 inch thick rotor.... Napa guy says the 2 inch thick rotor is the popular option.
next.... will a dually rotor have 9/16 holes where it is bolted to the hub? or still have the big 17.8 ish mm holes?
im lost on what I should do...
essentially im converting a srw 1ton front end to a drw 1ton front end... Mark, I allready bought these hubs from you, IDK what year truck they are from, and what calipers, rotors, and caliper brackets they would use..
