Pyrometer probe location ??
Postby holeshotracing » Wed Jan 17, 2007 10:12 am
I hope this is the right category for this question.
Where exactly should the pyrometer probe go? I have an Isspro just waiting to be installed. Thanks.
Black 1993 regular cab W250, G-trag, NP205, 262K, muffler gone, Isspro tach & boost
holeshotracing
Probe install
Postby sdstriper » Wed Jan 17, 2007 12:02 pm
http://www.dieselpage.com/gipda.htm
I drilled and tapped mine without removing a thing. Greased the drill bit and cleaned the shavings as I went, same with the tap. Used a magnet to "fish" what few shavings there were down in the exhaust manifold.
I drilled out this hose blank to run my pyro wiring thru. Worked out great, I have a triple gauge pod in the dash speaker hole.
http://www.1stgen.org/viewtopic.php?t=161
sdstriper
Postby TWorline » Wed Jan 17, 2007 6:39 pm
I did not remove anything either, drilled & tapped the manifold slow while the engine was running, the exhaust blew it all out the new hole.
Tim Worline
http://www.CoolerTubz.com/
TWorline
