front sway bar
front sway bar
Postby skilletky » Mon Jan 23, 2012 4:22 pm
Was looking at a pick of a truck like mine, 2wd drw lbs with 4k front axle, and noticed the truck had a front sway bar. Mine don't, did they not all come with one or was mine removed at some point in time.
skilletky
Re: front sway bar
Postby Mark Nixon » Tue Jan 24, 2012 10:46 pm
MOST 1 tons have them, some don't.
Same deal on 3/4 tons, I've never found a rhyme or reason as to why some do and some don't, just that I've seen a lot of these trucks and they seem to be missing/never there.
All diesel 4X4s were always equipped with them, but a good number of them don't have the bars, either.
Re: front sway bar
Postby skilletky » Wed Jan 25, 2012 12:04 am
Thank you mr mark. Wonder if would help out any if I equipped my truck with one.
skilletky
Re: front sway bar
Postby Mark Nixon » Wed Jan 25, 2012 10:37 am
skilletky wrote:Thank you mr mark. Wonder if would help out any if I equipped my truck with one.
It would help, but I've been noticing that people can't seem to find the end link kits for the 2wd ones.
It's possible that's WHY people remove them in the first place, simply because they can't fix them when they break.
Re: front sway bar
Postby skilletky » Wed Jan 25, 2012 11:25 pm
That's what I was thinking, I called around trying to find some parts and noons has anything except the bushings. Mark, if you happen to come across a complete setup with everything needed for install, let me know if ya want to sell it.
skilletky
Re: front sway bar
Postby ahale2772 » Thu Jan 26, 2012 9:45 am
my 2500 had one, and I removed it because of the links.
I wonder if trucks that did not come with front sway bars had the same upper axle plates with the tab for the swaybar?
Re: front sway bar
Postby ellis93 » Thu Jan 26, 2012 10:47 am
I couldn't imagine driving mine without one :yuck:
Re: front sway bar
Postby Horicon93 » Wed Feb 22, 2012 2:23 pm
Replaced all my swaybar bushings with Poly from Energy Suspensions just last Fall. So they're still available FYI.
'93 Extended Cab, DRW, 2WD, Auto, 4 1/2" stacks, Bone Stock
Horicon93
Re: front sway bar
Postby scottdevall@yahoo.com » Sat Feb 25, 2012 10:40 pm
so now i thought i new everything about the one ton 4*4, now i learn that all the 4*4 came with a say bar, which mine doesnt, is it commons to be removed or something.
and can they be mounted with a 4 inch lift kit
wait do they take off if the truck was in a front end collision
Re: front sway bar
Postby KTA » Wed Feb 29, 2012 9:25 pm
Dont feel bad I have two 4x4's a 92 and a 93 and neither has or does it appear that they ever had factory sway bars.
Re: front sway bar
Postby moab4x4 » Wed May 09, 2012 7:40 am
scottdevall@yahoo.com wrote:so now i thought i new everything about the one ton 4*4, now i learn that all the 4*4 came with a say bar, which mine doesnt, is it commons to be removed or something.
My 92 was missing the swaybar (but then again, one of the spring plates was installed backwards so the eye was in the wrong spot :roll: ) The 93 parts truck had one so I installed it.
With a 4" lift you need to drop the swaybar (2" IIRC) Skyjacker sells a drop bracket for that purpose. With the extra flex of the 4" lift the truck will handle better with the swaybar installed. I got pretty good at disconnecting the end links when I went wheeling then hooking it back up when I was done. I then had to take the swaybar off when I installed crossover steering and :shock: :mrgreen: 8) That truck handled better than I had ever experienced!!! Completely sold on the crossover steering now.
92 W350 LE Getrag, 3.54, 4"/2" lift,
HTT Stage II, POD's, 4", PDR cam, KDP, 3200 GSK, Pin ground, Keyed Valet
Pyro, Boost in Message Center, Isspro tach, Damplifier-ed entire cab! Dual Batts, Keyless Entry, LED's in dash
moab4x4
Re: front sway bar
Postby james1 » Wed May 23, 2012 2:19 pm
ahale2772 wrote:I wonder if trucks that did not come with front sway bars had the same upper axle plates with the tab for the swaybar?
Yes they did. My dad bought my W250 new and it came without a swaybar but with the tabs on the plates.
Note that the OEM swaybar is discontinued and when the parts manager at my local Dodge dealer checked his computer there is no dealer in the US still holding one -- so the junkyard is the only place to find one now. :cry:
james1
Re: front sway bar
Postby Diesel » Wed May 23, 2012 4:59 pm
If you find the bar in a junkyard you may just be able to find links from another application or just weld up a set.
1991.5 D250 Intercooled A518
Diesel
Re: front sway bar
Postby Mark Nixon » Wed May 23, 2012 5:06 pm
I still have a spare 4x4 bar, with the frame mounts, but no end links.
Someone asked about it a while back and I found out that it's still here.
