disc brakes front and rear 92 w250
Postby directinjktn1stgen » Sun Dec 09, 2012 3:20 pm
So Ive been thinking about converting rear drum brakes to disc. I found some info on a bracket system to bolt a chevy 2500 caliper on to it. then i was thinking since the local napa only has squealing front brake pads why not convert the front as well then i can run quailty pads and have some better stopping power. Any way if i do it im planning making everything easier on disassembly as well. I cant remember exactly how the front hub comes off i just know it was pretty rediculous compared to newer body styles dodge, ford and chevy. If anyone else in intreseted as well let me know and when i do it ill do a write up as well with lots of pictures but for now ill be doing research and getting prices and measurements for everything before i start.
1992 w250 4x4 4" custom turbo back exhaust 5x.012 HVLP lift pump 3200 181/210 M3 fuel pin, gated hx35 auto important meters
Jeffery
http://i1259.photobucket.com/albums/ii5 ... af0c34.jpg
directinjktn1stgen
Re: disc brakes front and rear 92 w250
Postby dazedandconfused » Sun Dec 09, 2012 3:47 pm
Why not just swap in a disc brake rear axle from a 2nd gen?
Postby directinjktn1stgen » Mon Dec 10, 2012 6:45 pm
well around me dodge cummins diesels are not to common i just figured it be a lot easier this way but thats not a bad idea thanks for the input
Jeffery
directinjktn1stgen
Postby RumbleFish » Mon Dec 10, 2012 7:40 pm
I converted a dana 60 to rear disc. It was pretty easy and worked great. It used chevy k20 front calipers on the rear. Only downside was that I didnt have a parking brake but the truck was an auto so it didnt matter to me much. s
Postby directinjktn1stgen » Sun Dec 16, 2012 11:45 am
did you fabricate brackets yourself ? how much money did youhave in it ?
Jeffery
directinjktn1stgen
Postby cmann250 » Sun Dec 16, 2012 12:13 pm
Your friend BC847 has rear discs on his truck if my memory serves me correctly. How did he do his?
Postby RumbleFish » Sun Dec 16, 2012 6:10 pm
I bought a kit off ebay. Had $300 in it with everything: brackets, calipers, pads, bolts, and hoses. It was about the same as buying the parts at the parts store and the brackets alone on ebay.
Postby cummins12club » Tue Dec 18, 2012 9:57 pm
RumbleFish wrote:I bought a kit off ebay. Had $300 in it with everything: brackets, calipers, pads, bolts, and hoses. It was about the same as buying the parts at the parts store and the brackets alone on ebay.
Was this a quality kit? How well did it improve stoping
cummins12club
Postby directinjktn1stgen » Thu Dec 20, 2012 7:04 pm
yes i found that out doing more research i should just asked him. If it can be done im sure he has done it. i think im goin to go that route i like a parking brake when it comes to checking tranny fluid in Neutral :lol:
Jeffery
directinjktn1stgen
