LIFT PUMP PSI
LIFT PUMP PSI
Postby AfricanEngineering » Mon Jul 01, 2013 6:52 pm
I have a 92 I/c motor I swapped into an 88 Chevy crew cab. I am getting ready to drive it 13 hours from Florida to Virginia for college and I'm looking to add a fuel pressure gauge to monitor the output of the lift pump. I have turned up the fuel pump. Rotated pin 90* 2 turns of star wheel and 1.5 turns of fuel screw.
So my question is what psi should the first gen diaphragm lift pump maintain?
Thanks,
Dave
AfricanEngineering
smoke screw?
Re: LIFT PUMP PSI
Postby Tacoclaw » Mon Jul 01, 2013 6:58 pm
The stock pump? I'd bet you'd be lucky to see more than 5psi out of one of those things. The more the better though, those things aren't physically capable of making enough pressure to hut anything.
Re: LIFT PUMP PSI
Postby AfricanEngineering » Mon Jul 01, 2013 7:04 pm
I was curious because I have heard all of these horror stories of the 24v vp44 and how they need to be properly fed. I am still fairly new to the ve
AfricanEngineering
smoke screw?
Re: LIFT PUMP PSI
Postby Tacoclaw » Mon Jul 01, 2013 7:21 pm
Oh, you want pressure, preferably in between 10-15psi, but I wouldn't expect to see it out of that LP. Any pressure is better than none.
Re: LIFT PUMP PSI
Postby RCCUMMINS89 » Mon Jul 01, 2013 7:49 pm
If you're running anything more than 0 psi............the pump will be ok with a stock or mild tune.
In fact, at a factory set up................0 psi won't cause issues.
Our injection pump's internal vane pump does a very good job (on a stock or nearly stock truck).
It's when you start turning up the power..........at all, that you'll want to start really watching that fuel pressure.
Now, all that aside...........the service manual says to maintain a minimum of 3 psi of fuel pressure.
Re: LIFT PUMP PSI
Postby ellis93 » Mon Jul 01, 2013 7:54 pm
Man no worries with the ve like the VP pumps,you could see 0 psi several times before anything happened.....with the VP about twice an it's fried.
Our pumps can suck its own fuel and live for quite a while.....tho its not recommended.
Re: LIFT PUMP PSI
Postby BILTIT » Tue Jul 02, 2013 7:45 am
Might aswell order one of these now, your going to need it.
http://shop.thehungrydiesel.com/Low-Pre ... t-Pump.htm
Derek B.
BILTIT
Re: LIFT PUMP PSI
Postby AfricanEngineering » Tue Jul 02, 2013 4:16 pm
Alright perfect because I found an auto meter pro comp liquid filled fuel pressure gauge that is from 0-15 psi 8)
Good to go thanks
AfricanEngineering
smoke screw?
Re: LIFT PUMP PSI
Postby Deathrod » Wed Jul 03, 2013 7:24 am
VW tdi ve pumps don't even have lift pumps at all...so I guess a ve is capable of sucking fuel on its own.
Deathrod
Re: LIFT PUMP PSI
Postby PToombs » Wed Jul 03, 2013 5:44 pm
If you plan on running 15psi, you should have a 30psi gauge. I read that you should try to choose a gauge about double what you plan on reading for longevity and accuracy.
Re: LIFT PUMP PSI
Postby 1992gen1_fan » Tue Jul 09, 2013 11:39 am
Optimal pressure for a stock LP is generally between 3-6 psi with a clean fuel filter.
1992gen1_fan
Re: LIFT PUMP PSI
Postby bmoeller » Fri Jul 12, 2013 6:25 pm
PToombs wrote:If you plan on running 15psi, you should have a 30psi gauge. I read that you should try to choose a gauge about double what you plan on reading for longevity and accuracy.
This is a great idea. Gauges tend to be the most acccurate in the mid-area of it's range of operation.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
