Re: '90 W250
Postby PToombs » Mon Dec 09, 2013 6:21 pm
Eric, that's why I quit drinking anything when I come on here. ;)
Re: '90 W250
Postby Tacoclaw » Mon Dec 09, 2013 7:33 pm
Got me a 2ndgen booster and master assembly with all the lines coming. I always knew my booster was popped but just never wanted to admit it. Finally stuffed our brake bleeder thing in the line and couldn't even try to pull a vacuum on it.
I'm betting my blowby will literally be cut in half when I plug that damn pump off. I've stashed a few parts off all the turbo cars I've had over the years, I've got an electric vacuum pump here that will probably be plenty to run the HVAC. Might have to find a vacuum switch for it so it doesn't run for no reason...
Re: '90 W250
Postby Tacoclaw » Thu Dec 26, 2013 6:01 pm
I put another actuator on the TB and threw a regulator before it to keep pressure down to 20psi. Been working fine, I'm just a little wary of the seeming lack of top end. Pulls damn good through third, but towards the upper end of 4th you can really feel it lay over. I can't remember how my IP is set up, but I set my AFC to go all the way down tonight.
Turbo runs 45psi but that's with a ported head and 188/220 cam. No more vacuum pulled on the interstage piping, the turbo is getting plenty of air.
I talked to Tyler and we're gonna swap my questionable 5x14's for his old DDP4's and see what happens.
My LP maintains 8psi on a hard pull as of right now, so if my injectors aren't limiting me I'm somewhat afraid my IP may be going retarded from lack of case pressure. I'll rig up a case pressure port after I try out his injectors. If his turn out to fix this problem I'll just look into another set.
Maybe somewhere in the 5x18-5x20 range, to shut Hineman up. :lol:
Re: '90 W250
Postby AHineman » Thu Dec 26, 2013 6:15 pm
You'll still have a smaller primary so.... :P
I've decided that if I have any extra money now that I'll just burn it and save the trouble. :roll:
Re: '90 W250
Postby cmann250 » Thu Dec 26, 2013 6:21 pm
AHineman wrote:I've decided that if I have any extra money now that I'll just burn it and save the trouble. :roll:
Quoted for the awesome level of trueness! :lol:
Re: '90 W250
Postby Tacoclaw » Thu Dec 26, 2013 9:01 pm
Look on the bright side, Hiney, we could be spending money on these things because we had to, not because we wanted to. What fun would that be?
Speaking of, my heater hoses aren't leaking. :(
Re: '90 W250
Postby PToombs » Fri Dec 27, 2013 6:57 pm
Scared the piss out of the GF? :lol:
Re: '90 W250
Postby DodgeFreak » Thu Jan 02, 2014 6:35 pm
So.....the whole hx shaft in an 351 housing....it won't work......well it might....lol the turbine wheel on the hx must step down differently. the wheel bottoms out before the housing does. It might need to be machined down.. or something...I'll need to measure some more.
Re: '90 W250
Postby Tacoclaw » Thu Jan 02, 2014 6:49 pm
It bottoms on the verticle surface of the blades before the v-bands close up?
That totally blows, how much interference is there?
Re: '90 W250
Postby DodgeFreak » Thu Jan 02, 2014 7:40 pm
I think I'm going to start my own thread so I don't interfere with your well informed thread you have started...I don't want to hi jack it...LOL..
Re: '90 W250
Postby Tacoclaw » Thu Jan 02, 2014 8:12 pm
Shit, I haven't posted in here in forever. :lol:
I'll be back when I start fab on the airbag suspension, until then it's a free for all.
Re: '90 W250
Postby DMan1198 » Thu Jan 02, 2014 8:31 pm
Free for all and all for free
Re: '90 W250
Postby ellis93 » Fri Jan 03, 2014 8:45 am
I came back this morning looking for progress.....alas it's just like prom night,horridly disappointed....again :(
Re: '90 W250
Postby AHineman » Fri Jan 03, 2014 10:44 am
Disappointing for your date? :P
Re: '90 W250
Postby Tacoclaw » Fri Jan 03, 2014 10:45 am
I'd say Pete had a decent time.
Users browsing this forum: No registered users and 73 guests
