Camplate R&D
Postby apwatson50 » Fri Feb 08, 2008 6:59 am
Is there any reason why you couldn't run this cam plate with stock 12mm pump head/plunger?
I'd also like to verify the high rpm return spring numbers. The number I have is:
1-467-010-410
Thanks, Aaron
92 Cummins, 4x4, 270K miles
apwatson50
Postby ford69557ci » Fri Feb 08, 2008 7:08 am
well the point of the higher lift cam plate is to deliver more fuel and in order to do that the 12mm h&r has to go. without that its kinda pointless
ford69557ci
Postby apwatson50 » Fri Feb 08, 2008 9:00 am
But with a higher lift cam plate couldn't the 12mm h&r deliver more fuel?
Obviously not as much as with a 14mm h&r, but still more.
Aaron
apwatson50
Postby rockjeep73 » Fri Feb 08, 2008 11:45 am
apwatson50 wrote:But with a higher lift cam plate couldn't the 12mm h&r deliver more fuel?
Aaron
Yes it will.
2000 QCLB 2500 4x4, 12.05 @ 111
89 D-250, In The Graveyard
89 W-250, Mostly Stock
http://www.SHSDiesel.com
rockjeep73
Postby cummins king » Fri Feb 08, 2008 12:16 pm
yes it will how much more? is the question you can only put so much fuel trough the 12mm, the whole point of the cam is to get more fule because the 14mm isnt enough, and with a 4mm your only aprox. 16% more fuel from stock, a 14mm is way more
93 4X4 auto
cummins king
Postby bgilbert » Fri Feb 08, 2008 2:19 pm
apwatson50 wrote:I'd also like to verify the high rpm return spring numbers. The number I have is:
1-467-010-410
Thanks, Aaron
That is the part number KTA, Stomp and Scheid Diesel use. It comes as a spring set. You'll get the plate, two washers and two springs. Can't remember the price, while ordering at Scheid recently, I asked if they were the high rpm app, they didn't know, just said those were the only ones they stock and use. They are a different color than stock, bluish iirc.
Bill Gilbert
Postby apwatson50 » Fri Feb 08, 2008 2:57 pm
bgilbert wrote:That is the part number KTA, Stomp and Scheid Diesel use. It comes as a spring set. You'll get the plate, two washers and two springs. Can't remember the price, while ordering at Scheid recently, I asked if they were the high rpm app, they didn't know, just said those were the only ones they stock and use. They are a different color than stock, bluish iirc.
Thanks for the info. If they are good enough for those guys, it will be good enough for me.
apwatson50
Postby rockjeep73 » Fri Feb 08, 2008 3:06 pm
cummins king wrote:yes it will how much more? is the question you can only put so much fuel trough the 12mm, the whole point of the cam is to get more fule because the 14mm isnt enough, and with a 4mm your only aprox. 16% more fuel from stock, a 14mm is way more
Going to a 14mm with a stock cam is a 36% increase in volume.
With a stock 12mm rotor, switching to a 4mm cam, stock is 3.2mm, you will increase volume by 25%.
rockjeep73
Postby cummins king » Fri Feb 08, 2008 4:32 pm
well my cam stock is 3.4 mm witch is 3.5 that is warn and goin to 4mm is aprox 16% more
93 4X4 auto
cummins king
Postby apwatson50 » Tue Feb 19, 2008 1:46 pm
So does anyone know of a factory Bosch 6 cylinder pump with the 4.0mm cam plate?
apwatson50
Postby ford69557ci » Tue Feb 19, 2008 1:54 pm
the 4mm and 4.5mm that i have are custom pieces that are no longer inproduction but the company that was building them is supposed to start makin them again here in a few months.
ford69557ci
Postby apwatson50 » Tue Feb 19, 2008 2:14 pm
ford69557ci wrote:the 4mm and 4.5mm that i have are custom pieces that are no longer inproduction but the company that was building them is supposed to start makin them again here in a few months.
Yeah I emailed them and they said they were planning on a production run in the next month or so. But I thought that there might be a factory pump may have a higher lift plate and I could get a factory bosch piece. But I guess i'll just have to wait if I want one.
apwatson50
Postby DTanklage » Tue Feb 19, 2008 4:09 pm
how do you figure?
i come up with less than 20% increase
DTanklage
Postby JD730 » Tue Feb 19, 2008 4:44 pm
DTanklage wrote:
how do you figure?
I come up with .395... cc's for a 12mm plunger with 3.5mm's of lift and .538 cc's for a 14mm at the same lift.
.538-.395=.143
.143/.395=.362 which would be 36.2%
and to check it quickly, .395*1.362=.538
Mike
The "Rattle Box"
JD730
Postby cummins king » Tue Feb 19, 2008 5:01 pm
JD730 wrote:
DTanklage wrote:
how do you figure?
.538-.395=.143
sounds about right
i placed an orter for 3, 4mm cames from them, delivery is supost to be mid march,
Joel
93 4X4 auto
cummins king
