Tacoclaw wrote: The shutoff solenoid is a bastard on those pumps, if you don't go pull cable you'll have to setup a dedicated pull wire hooked to your start circuit.
ellis93 wrote:Tacoclaw wrote: The shutoff solenoid is a bastard on those pumps, if you don't go pull cable you'll have to setup a dedicated pull wire hooked to your start circuit.
Easy fix.....run a wire from the motor side of the starter solenoid then attach the other end of the wire to the pull coil on the shutdown solenoid.....fixedno fancy foot work required
ellis93 wrote:That's what it read like to me,I just read Levi's post and put a little fyi to it.
PToombs wrote:You need to pull the cam to swap the timing case. Pretty sure the gears on the cam are the same and don't need to be swapped.
