Postby RCCUMMINS89 » Mon Jun 09, 2014 7:43 pm
Postby DodgeFreak » Mon Jun 09, 2014 7:54 pm
ellis93 wrote:
dazedandconfused wrote:Its only what a foot longer then yours Ellis?
Gotta be more than that,or it's the blue paint.
Honestly I like the truck,I'd like to do something like that but with a chevy. They're more common than the dodge counterparts. Parts are easier to get as well.
Oh just to find that "right" one. :roll:
The crew ferd ran all day today with fresh oil and that rev-x stuff. Guess we'll see if it starts up better in the morning.
from the back of the front door to the rear of the cab is roughly 3'4". I Briefly thought about buying a crewcab furd (93) but that thought left my mind rather quickly lol....I really want mine to be a dually.
Postby RumbleFish » Tue Jun 10, 2014 6:19 am
DodgeFreak wrote:
RumbleFish wrote:Sometimes I miss my crew cab. But when I go to leave for work in the mornings, and my truck actually starts, Im done missing it.
So far Mines started everytime :D I think the Rattily engine has something to do with that though lol.
I bought mine already swapped. The po did all the work. Lets just say he shoudnt be allowed to wire ANYTHING. I had to fix it once or twice a week just to get to work...and that was 3 miles down the road.
Postby DodgeFreak » Tue Jun 10, 2014 9:48 am
So question.....if you was going to swap a crew to 4wd. Would you run
A) a divorced 205 and keep the getrag
Or
B) swap in the a518\205 setup.
or
C) convert 518 to lockup\205 setup.
Postby dazedandconfused » Tue Jun 10, 2014 9:56 am
If its parts I had I'd build the 518 and put in myself. I've never cared for how the get rag felt shifting. That's just me though.
Postby DMan1198 » Tue Jun 10, 2014 11:11 am
I'd go divorced with the getrag. Mostly because not many people see one so it'd be a good conversation starter
Postby cmann250 » Tue Jun 10, 2014 1:26 pm
I'm a built auto kind of guy, so B unless you have the parts for C. Can you even find divorced 205?
Postby ellis93 » Tue Jun 10, 2014 1:39 pm
dazedandconfused wrote:If its parts I had I'd build the 518 and put in myself. I've never cared for how the get rag felt shifting. That's just me though.
It shifts like any other manual in a 3/4 or ton truck. Unless it's a ford your comparing,then you grind'em till you find them :lol:
I can shift mine pretty fast,faster than the truck likes to go ;)
I say leave the manual in it regardless.
Postby RumbleFish » Tue Jun 10, 2014 2:18 pm
Leave the man trans! Its like a theft deterrent around here. Personally, I hate autos so Id go with whatever option will hang a clutch pedal in front of you.
Postby CumminsPower59 » Tue Jun 10, 2014 3:57 pm
Divorced 205's in both Dodge and Ford varieties are quite plentiful around here, seen them as cheap as $150...it would be pretty easy to twin stick it too since there wouldn't be clearance issues...
Postby DMan1198 » Tue Jun 10, 2014 4:56 pm
There's a possibility I may be able to buy a 97 dodge that has a destroyed clutch. That is if the owners decide they don't want to fix it
Postby DodgeFreak » Tue Jun 10, 2014 5:09 pm
CumminsPower59 wrote:Divorced 205's in both Dodge and Ford varieties are quite plentiful around here, seen them as cheap as $150...it would be pretty easy to twin stick it too since there wouldn't be clearance issues...
:D my thoughts exactly.......I don't need a twin stick but ever since I was little I've always wanted a truck with a twin stick....and now I want a doubler with 203\205 with a triple stick. why I don't know.....especially in a crew. I have a 205 divorced but it needs gone through. Do you know if I can use parts out of a married 205 in a divorced 205?
Postby CumminsPower59 » Tue Jun 10, 2014 7:37 pm
Inputs are obviously different, not sure on outputs. I would guess they are the same. Most small parts are interchangeable regardless of what it was in. Best thing to do is put them side by side, pull the yokes, count the splines and see if stuff matches up.
Postby redneckroot » Tue Jun 10, 2014 8:05 pm
I would go option d. Nv4500 with a either a flipped 271 or married 205.
redneckroot
Postby DodgeFreak » Tue Jun 10, 2014 8:11 pm
if I was going to swap trans I would go with the G56.....I want a 6spd
