http://youtu.be/K3yohoCqD2E
I'd chunk the cummins idea to the side,nothing beats that Detroit sound
oldestof11 wrote:I know Meby did it.
I'd love an ALH TDI powered Subaru.
ellis93 wrote:It's in the 20s right now.....how cold does it need to be before you except the fact that this is a ppump enigne with 18+* of timing![]()
I'm good now tho....the factory one was bad. It's cranking easier with the 24v unit,still won't warm the water enough for warm air in the cab at start up.....the dodge does tho,it's dead tho.....more on that later
txs wrote:Friends 04 has transfer case slipping, he says front driveshaft kinda ratchets when in 4x, I'm thinking its either shift fork or chain. I believe they had the 273 tcase. He plows with it so I think either one could be worn out.
