23 spline to 29 spline Adapter, Any Interest?
Postby rockjeep73 » Sun Jan 24, 2010 12:50 pm
Just curious if there is any interest out there for a 23 to 29 spline coupler for mating a 5 speed np205 with the big 29 spline input behind an auto with the smaller 23 spline output.
I am asking because after breaking a transfer case input shaft in my brothers truck he bought a 5 speed transfer case and we built a 23 to 29 spline coupler. We have had the coupler in the truck for about a year now and it it has held up to dozens of sled pulls and drag races at around 700hp.
Correct me if I am wrong but as far as I know there isn't anything like this available. I am looking for some feedback on this part and how much you would be willing to pay.
2000 QCLB 2500 4x4, 12.05 @ 111
89 D-250, In The Graveyard
89 W-250, Mostly Stock
http://www.SHSDiesel.com
rockjeep73
Postby Richie O » Sun Jan 24, 2010 12:57 pm
There would be some interest for sure. It would have to be strong. Sounds like your on that.
Postby doublel89 » Sun Jan 24, 2010 2:19 pm
Trying to get a auto to manual conversion done in my truck, would it be more cost effective than swapping transfer cases?
91 3/4 Ton 4x4, 5.9 Cummins,DDP Fuel Pin I usually leave it out though, DDP 40 Horse Sticks, HX35W And 2nd Gen Intercooler, Single 5'' Trunout, NV5600 Swap, Dually Conversion, 3.08 Rear Gears, Soon A Custom Hauler Bed
doublel89
Postby rockjeep73 » Sun Jan 24, 2010 2:24 pm
Ya strength was my biggest concern and I was worried about how it would hold up, but like I said it has been abused and proven so far.
The truck that it's currently in is under going its next round of changes and will likely be closer to 800hp when finished so we will continue to punish the coupler, but at this point I doubt it will fail.
rockjeep73
Postby rockjeep73 » Sun Jan 24, 2010 2:29 pm
doublel89 wrote:Trying to get a auto to manual conversion done in my truck, would it be more cost effective than swapping transfer cases?
That depends on how much transfer cases are selling for. My intention with the coupler is to be able to run the stronger 5 speed t-case behind an auto, but it will also work for your application of an auto t-case behind a 5 speed trans.
Im not sure on pricing yet and I would like some input on what would be reasonable.
rockjeep73
Postby DZL_Damon » Sun Jan 24, 2010 8:42 pm
the 23 splines are easier to come by, and already available for many of us switching to a manual tranny. I have a divorced unit coming my way for my swap, but maybe I could keep my 23 spline with a coupler and sell the divorced NP205 again.
Price is the queston now. Depending on price, I would probably be a customer.
-93 W350,CC, DRW, A518, Pump maxed, DDP3, DennyT, 4" DP, black muffler stack with flapper. HE351cw, CoolerTubz, PS I/C, 4601HP elec. fuel pump, 205k
-89 D250, clean utility bed, TF727, new IP, 76k
-09 VW TDI 2.0L CR, ~45mpg, 20k
DZL_Damon
Postby Mark Nixon » Sun Jan 24, 2010 9:50 pm
I have a 29/23 combo coupler here that a guy I know also used for sled pulling.
He broke a couple 23 spline cases and finally upgraded to a 29 spline.
The coupler held up quite well.
He's a certified welder and has a machine shop to use, and he does good work.
Postby DZL_Damon » Mon Jan 25, 2010 5:47 pm
That's good new Mark. So the Transfercase will blow before the coupler... Probably good enough for most of us wanting a stick...
DZL_Damon
Postby Mark Nixon » Tue Jan 26, 2010 7:05 pm
More power than I'd care to make with a 4x4.
Re: 23 spline to 29 spline Adapter, Any Interest?
Postby dodge1stgen » Wed Feb 17, 2010 6:53 pm
did you get a price on then yet might want 1 or 2 thanks Eric
93 250 ext cab p pump injectors 2 disk clutch 3'' charger nv 4500 retired
92 350 ext cab 5 spd 366 spring bd injectors hx 35 dana 80 flatbed
92 350 converter built trans bd fuel pin flatbed/dumpbed
dodge1stgen
Postby Mark Nixon » Fri Feb 19, 2010 9:48 am
I can say that it won't be any cheaper than a new 29 or 23 spline coupler.
I could use a few of both to do this, though it's GFL finding somone who has 29 spline ones with no use for them.
Right now all I have is enough to do 1 combo.
Postby rockjeep73 » Sun Feb 21, 2010 1:28 am
Here is what I got...
$150 with exchange of stock 23 spline coupler
$180 with exchange of stock 29 spline coupler
$220 outright
I have one sitting here ready to go.
rockjeep73
Postby BobS » Sun Feb 21, 2010 6:54 am
Do those have the provision for the internal snap ring to keep it from walking fore and aft on the splines or a way that it always remains in the correct position?
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby rockjeep73 » Sun Feb 21, 2010 12:27 pm
No they do not as I didnt feel that it was necessary, but it is something that would be easy for me to add. When the coupler is slid onto the transmission output shaft there is no way for it to go too far on, due to the length and shape of the output shaft. As far as being turned around and used on a 23 spline transfer case that is something I will have to look into, if the shaft stops it from going to far in that direction then there really is no reason for the snap ring.
rockjeep73
Postby rockjeep73 » Wed Feb 24, 2010 11:13 am
you can purchase them here...
www.SHSDiesel.com
rockjeep73
Users browsing this forum: No registered users and 73 guests
