axle ratio
axle ratio
Postby spencermumma » Mon Mar 12, 2012 11:29 am
I am looking to.run.3.55 or 4.10 gearing wondering if I were able to take a gasser rearend and make it work in a Cummins? Is it even Dana 60/70 ? Don't want.the 3.07 axle ratio or is there any way to.just change gearing? I know its Ben talked about before but I'm confused on if you can chnge the geari.g or not?
Thanks spencer
1990 Dodge W250 5 inch stacks no muffler, Star wheel bottomed out, Smoke screw turned all the way, Fuel screw maxed, Denny T Fuel Pin, 2inch lift with 33x12.50 and alot more to come shooting for 450 horsepower any suggestions?
spencermumma
Re: axle ratio
Postby cmann250 » Mon Mar 12, 2012 12:26 pm
I'm not an expert by any means, but my understanding is this: If you have 3.07s, you can get lower (higher numerically) gears, but if you have lower (ex. 4.10s) gears you cannot go to 3.07s. This is because the 3.07s are physically bigger and technically the 3.07 axles are D61/71. All of this assumes you are keeping the axles and just changing the ping and pinion. As far as using a different axle, I believe the gassers have the same rearend and a D70 is a D70, gas or diesel. I also don't think the gassers typically had the D60 front end, so that may be an issue.
I'm sure someone with more know how will chime in
Re: axle ratio
Postby oldestof11 » Mon Mar 12, 2012 2:12 pm
Dana 70's and Dana 80's are what you want, not a 60. Judging by your sig, you like to play. A 60 would not be ideal.
Trade your 3.07's for someone who has 3.55's or 4.10's.
Also understand, max speed will be about 60mpg @ 2300 rpms without OD.
Re: axle ratio
Postby spencermumma » Tue Mar 13, 2012 3:21 am
It's getting a billet 47rh so the od will be there
spencermumma
Re: axle ratio
Postby hemislave » Tue Mar 13, 2012 10:45 am
spencermumma wrote:I am looking to.run.3.55 or 4.10 gearing wondering if I were able to take a gasser rearend and make it work in a Cummins? Is it even Dana 60/70 ? Don't want.the 3.07 axle ratio or is there any way to.just change gearing? I know its Ben talked about before but I'm confused on if you can chnge the geari.g or not?
Thanks spencer
Have you thought about swapping complete rears with someone who might want to trade? where in Indiana are you?
85 crew cab 1st gen ve pump tweaked a lil. 4:10s auoto o/d gauges boost,pyro. 16cm exhaust housing .285/75/16 nitto terra grapplers,rebuilt a518 w/a decent torque converter.
hemislave
Re: axle ratio
Postby spencermumma » Tue Mar 13, 2012 6:22 pm
Yes and ft Wayne Indiana
spencermumma
Re: axle ratio
Postby spencermumma » Wed Mar 21, 2012 11:26 am
Could you just swap 4.10 ring and pinion to an axle that has 3.07?
Spencer
spencermumma
Re: axle ratio
Postby cmann250 » Wed Mar 21, 2012 1:39 pm
Yes I believe so, but you can't do the opposite
Re: axle ratio
Postby Philip » Wed Mar 21, 2012 5:17 pm
spencermumma wrote:Could you just swap 4.10 ring and pinion to an axle that has 3.07?
Spencer
No
The 3:07 is called a Dana 71. It has the pinion offset about 1/2" to the passenger side of the axle. Here is a pic of a 3:07 pinion beside a 3:54 pinion.
Re: axle ratio
Postby Tacoclaw » Wed Mar 21, 2012 5:19 pm
You mean what's left of a 3.54 pinion. :mrgreen:
Re: axle ratio
Postby cmann250 » Wed Mar 21, 2012 5:30 pm
Oh I guess there's more to it than I understood. Thanks for setting me straight Philip :)
Re: axle ratio
Postby Philip » Thu Mar 22, 2012 5:30 pm
Tacoclaw wrote:You mean what's left of a 3.54 pinion. :mrgreen:
Hea that is a lite weight model pinion. :lol: :lol:
Re: axle ratio
Postby PToombs » Fri Mar 23, 2012 5:40 pm
No, that's the medium weight pinion. The lite weight one has no teeth on it. :lol:
Re: axle ratio
Postby bmoeller » Sat Mar 24, 2012 4:17 pm
I thought the axles with the 3.07 gears couldn't change gear sets. Complete axle swap only?
3.55 to 4.10 or the other way around, you have to change the carrier as well. Not just swap gear sets.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Re: axle ratio
Postby Philip » Sat Mar 24, 2012 5:38 pm
The carrier is the same for 4:10 and down gearing. It doesn't matter if its a Dana 70 or 71. Any gears above a 4:10 ratio require a different carrier.
The AAM is the axle that has a couple of different carriers used below 4:10 ratio's.
