2 questions..wheels and rear leaf
Postby jorez » Thu Mar 22, 2012 8:39 am
1. Will a set of 2003 Ram 17" wheels fit a 1991 d150 properly?
2. I was searching a forum and found a post that stated that the leaf spring in the rear of a 91 d150 can be replaced with a leaf spring from a 1994-2001 ram 1500...is this true? The post said you can get a Belltech dropped 4" spring and it is a direct replacement...
Any idea on either of these questions?
jorez
Re: 2 questions..wheels and rear leaf
Postby Mark Nixon » Thu Mar 22, 2012 10:58 am
1. With wheel spacers they will clear.
2. No. The spring centers are different, as is the overall length, though the half ton and 3/4 ton gassers ARE the same width across the spring as 1st gens, at 2.5".
Additionally, when I have questions like these, it always initiates a visit to the junkyards with a tape measure to chase down the rumors.
Some of the Dodge guys are running Chevy springs and relocated mounts for the longer Chevy springs, so I suppose you COULD do the same and run the later Dodge set-up, but really, what is the point?
Postby jorez » Thu Mar 22, 2012 11:40 am
Thanks! at least now i wont wast the money!
jorez
