My Flatbed Swap
Re: My Flatbed Swap
Postby Hansen01 » Fri Aug 03, 2012 1:56 pm
lol oh, i member now, didnt remember if it was the same guy,but still everyone likes to see flames :mrgreen:
Under construction...
Hansen01
Re: My Flatbed Swap
Postby Burritoboi5 » Fri Aug 03, 2012 7:23 pm
Hey gents got some more done today.
Here's my m715 4bt powered with an hx35 for those who commented
I sprayed the rear of the truck the color it will all be
And here's the new lights
Got a lot more wood done, still one last board to get in
And here's the stack all mounted. Two of the bolts by some stroke of luck lined up with the angle iron beneath the wood
Hoping to finish the wood tomorrow and mount the bed
-Kriv
Burritoboi5
Re: My Flatbed Swap
Postby Burritoboi5 » Fri Aug 03, 2012 7:25 pm
flame thrower
Burritoboi5
Re: My Flatbed Swap
Postby Burritoboi5 » Sat Aug 04, 2012 12:46 pm
Got her on today gents.
Here's our lifting aparratus
Got the rear glass in again and made the spacers for the frame. Monday I'll get the Ubolts to hold her down.
Kriv
Burritoboi5
Re: My Flatbed Swap
Postby oldsoul » Sat Aug 04, 2012 5:56 pm
Very cool man! No gooseneck?
oldsoul
Re: My Flatbed Swap
Postby PToombs » Sun Aug 05, 2012 6:46 am
Why didn't you get some round lights to go in the holes in the bed? LEDs can be had reasonable and are brighter than heck. The wood looks awesome! 8)
Re: My Flatbed Swap
Postby Burritoboi5 » Sun Aug 05, 2012 1:55 pm
Thanks guys, actually did go with LEDs for the holes in the deck. They're amber strobes though, they'll get hooked up once my toolboxes come in. Today I was able to get the exhaust run. Had to rework the trans crossmember but it's 4in all the way to the stack now. Tomorrow I'll get some ubolts, and she should be road worthy.
Burritoboi5
Re: My Flatbed Swap
Postby Burritoboi5 » Sun Aug 05, 2012 7:08 pm
oldsoul wrote:Very cool man! No gooseneck?
Yeah I thought about the gooseneck, but I really have no use for one. The deck height is also every bit of 47 inches. Most of my towing is with equipment trailers on pintle hitches, hence the dual pintles off the rear.
Tomorrow I am getting my u bolts made and mounting the bed, also I plan on wiring up my rear clearance lights. Once I get some more cash I found the toolboxes I'm going to run, some 30x18x18 UWS aluminum's.
Burritoboi5
Re: My Flatbed Swap
Postby Burritoboi5 » Mon Aug 06, 2012 9:18 pm
Hey Gents, I got the u bolts made today and the bed is securely in place. I also mounted and wired my rear clearance/marker lights. They're 3/4 round LEDs. They are a little brighter than they look in the picture.
-Kriv
Burritoboi5
Re: My Flatbed Swap
Postby Tacoclaw » Tue Aug 07, 2012 9:48 am
I won't say I like the flatbed because I have a reputation to upkeep, but that's some good looking work you've done, man.
Sharp truck. 8)
Re: My Flatbed Swap
Postby PToombs » Tue Aug 07, 2012 4:03 pm
Looking good man! 8)
Levi, we know about your reputation, :flower:
Re: My Flatbed Swap
Postby Tacoclaw » Tue Aug 07, 2012 4:45 pm
Hmmm, I don't usually just walk into an easy one like that. :?
I must have let my guard down since I was working so hard today. I didn't have time to think about it.
Pete, I figure this smiley would have been better: :queen:
Re: My Flatbed Swap
Postby comotionman » Tue Aug 07, 2012 6:54 pm
looks pretty good, but can we see a pick with both rear wheels on it? how wide is that bed? does the bed cover the wheels? also if you only bolted the bed on with u-bolts, you should start thinking about welding a plate onto the channels that ride on top of the frame and then bolt it to the frame. otherwise if that bed gets hit your cab is going to be in trouble.also beds and boxes held on with u-bolts usually have complete contact along the entire length of the frame with a wood isolator in between. take a look at any medium duty truck and see how they do it. can you show some detail pics of the u-bolts and spacers? sounds like you kinda mixed bolt on and u-bolt on methodology. at any rate you need the plates to be safe(r).
coupla trucks non & ic, 2nd gens, various other
comotionman
Re: My Flatbed Swap
Postby Burritoboi5 » Tue Aug 07, 2012 9:21 pm
comotionman wrote:looks pretty good, but can we see a pick with both rear wheels on it? how wide is that bed? does the bed cover the wheels? also if you only bolted the bed on with u-bolts, you should start thinking about welding a plate onto the channels that ride on top of the frame and then bolt it to the frame. otherwise if that bed gets hit your cab is going to be in trouble.also beds and boxes held on with u-bolts usually have complete contact along the entire length of the frame with a wood isolator in between. take a look at any medium duty truck and see how they do it. can you show some detail pics of the u-bolts and spacers? sounds like you kinda mixed bolt on and u-bolt on methodology. at any rate you need the plates to be safe(r).
Having my new wheels mounted tomorrow so pics of all six on the ground then. It should cover both of them based on my measurements though.
Also, the rear mounts are U bolts, and the front are 1/4 plate with 9/16th grade 8 hardware welded to the frame. Couldn't fit a Ubolt between the driver side front frame rail and the tank even if I wanted to. My spacer are wooden, and 2 feet long in the front and rear as well as the middle hump section for contact everywhere except the rise/run sections.
-Kriv
Burritoboi5
Re: My Flatbed Swap
Postby Burritoboi5 » Wed Aug 08, 2012 6:12 am
The wheels the morons ordered don't fit on my 5/8th studs. What the *&%^ This is really bothering me.
Burritoboi5
