oldsoul wrote:Very cool man! No gooseneck?
comotionman wrote:looks pretty good, but can we see a pick with both rear wheels on it? how wide is that bed? does the bed cover the wheels? also if you only bolted the bed on with u-bolts, you should start thinking about welding a plate onto the channels that ride on top of the frame and then bolt it to the frame. otherwise if that bed gets hit your cab is going to be in trouble.also beds and boxes held on with u-bolts usually have complete contact along the entire length of the frame with a wood isolator in between. take a look at any medium duty truck and see how they do it. can you show some detail pics of the u-bolts and spacers? sounds like you kinda mixed bolt on and u-bolt on methodology. at any rate you need the plates to be safe(r).
